21 - 40 of 168 Posts
I like the lowered look, any chance the fender lip contacts the tire in a hard turn?
If you like how mine looks, I can PM you the details on how to get it there in the adjustments... it took a lot of trial and error on my part. Keep in mind, it may settle another 1/4" from what I pictured..
Rather than a PM (or a bunch of PM's), why not do a write up and post it for everyone to follow? I know I'll be interested in this for my Hellcat.
StellasHC Looks perfect to me I think it should have came that way from the factory. I was going to look into lowering my HC I'm sure there will be a few options soon but this kit being adjustable is awesome great job.
Reactions: StellasHC
Discussion starter · #27 ·
I know some have expressed interest in the kit I used, and BossHawg has purchased one. So, in order to save you guys the time, I will give some tips here for installing...
I bought the KW kit, part # 25327018. I paid $725 shipped, I have since seen it for as low as $650 shipped.. They cost twice what regular drop coils cost, but offer FULL height adjustment. They are listed for a 1" drop, but they will go to 2"-2.5" easily...
You can see there is a black base/seat on the rear spring, and a gold one for the front. These are threaded and the purple collar will adjust the height. To get 1" drop, I adjusted the purple collar in the rear 10 TURNS from the bottom. That gave me exactly 1 inch. I was lucky, because on the rear, you have to remove the spring again to make adjustments, which takes a little bit of time. I nailed it on the first try. When doing the rears, I use the "cradle" method. This involves lowering the rear cradle one side at a time. Others have just dropped the rear control arm. I dont like the idea of lowering and raising a control arm under spring tension, so I drop the cradle. Leaving the opposite side cradle bolts tight when dropping should NOT affect alignment..
The front, I ended up adjusting the purple collar up 3/4" from the gold base. I cant say how many turns, because it took about 4 tries to get the 1" drop I was looking for, and I lost count. When you make height adjustments, you would think that moving the base and adjusment collar apart 1/4" would affect height 1/4" but it doesnt work that way.
Here are the instructions I used. The KWs come with instructions that are marginal at best...
http://ekazsrt8.net/documents/P5155436.pdf
This job is actually pretty simple. You will need basic tools, along with a couple floor jacks and stands. You WILL need a strut spring compressor to do the fronts, or you will have to bring the front assemblies to a shop to remove the stock springs. You will also need a good torque wrench. I used air tools this time around, but on my last SRT, I did everything by hand. New cars come apart pretty easy..
Im going to say that a number of springs will work on our cars... Mopar Stage 1s, H&Rs, Eibachs, etc.. All at half the price. But, none will offer height adjustment like the KWs...
If somebody has ?s, post up, I will do my best to answer..
Good Luck!
Very nice! I had coilovers on my 2010 and before I took delivery of the Hellcat I figured I would lower it immediately but I'm actually liking the stock stance and is not that much higher than what I was running.
Unlike other cars where I've had coilovers I hate that the rears are not as easily adjustable as the front. :(
Reactions: 630 and StellasHC
Took the time to install my KW springs today... Install wasnt too bad. It took me about 4 hours crawling aroung by myself. A lot of that time was taking the wheels on and off to make height adjustments.. And another 1/2 hour was needed to run to the store to buy 2 set screws that were needed and some crazy German neglected to include....
The spings are fully adjustable height wise. I ended up adjusting the car down 1" all the way around. I measured from the ground to the front and rear wheel lips, and also the front splitter to gauge the difference... I will give the car few hundred miles to "settle", as they mention the car may settle another .2"-.3".... Then I will have the alignment checked..
Ride quality, honestly, has not been affected AT ALL... rides quality is exactly the same in all 3 Suspension Modes, but is definetly less "floaty" when in "Street" mode, which is what I use on our wonderful Wisconsin roadways...
Before and after pics... thoughts? I am VERY happy with the look...
View attachment 6037 View attachment 6038
Awesome gonna share on FB Hellcat page, thanks for sharing
Looks killer! what is your clearance now at the front splitter? Thanks for sharing. Great info.
Thank you so much. I have these sitting in my trunk right now and was going to have them put on thursday. Since a shop is going to be doing it for me, having your instructions on how much to lower it really helps.
The instructions are mostly in german, so im lost.
Thanks soooo much
Discussion starter · #33 ·
Tammie, the clearance at the splitter at stock ride height was 6 5/8" all the way around. After lowering, it is now 5 3/4"... I have steep approaches on both of my driveways and havent scraped....
Discussion starter · #34 ·
Thanks soooo much
Good Luck!
Discussion starter · #35 ·
Looks sick. Gonna order tomorrow. Tks again
Did you order direct or through other outlet??
Purchased off of Ebay from seller "tier1motorsports" ... Offered $725 shipped,had a tracking number in 20 minutes and they were delivered 2 days later...
Thanks. It looks awesome, I'm just not sure if I could pull it off on our roads here. Anxious to hear if it changes the performance. :)
All the while you were doing the installation, were you singing these lyrics?
All my friends know the low rider
The low rider is a little higher
Low rider drives a little slower
Low rider is a real goer
Low rider knows every street, yeah
Low rider is the one to meet, yeah
Low rider don't use no gas now
Low rider don't drive too fast
Take a little trip, take a little trip
Take a little trip and see
Take a little trip with me
Discussion starter · #38 ·
Uuuuuuhhhhhhh..............no
